72 JD 400 WILL NOT IDLE
Parts are in, the 027 points look slightly different than the 025's. Does anyone know if I put the 027's in & it really calls for the 025 will I damage anything. Every source (except one) that I have found recommends the 025 points for '72 400's
I did check the throttle shaft, no slop, tight as a drum.
Does anyone know the OEM # for the proper set of points for a 1972 John deere 400 with a KEC-340 engine?
Thanks!! As I understand it, the AM 53064 is the JD#. What would be the original CCW #?
Just went to Jdparts.com, there parts books only go back to 1975 & I have a 1972.
I'm looking in a original '72 parts book. As Rich earlier stated;
Model 400 points are listed as: AM52375 CCW number: 18000510
Thanks!! I did end up going to JD & getting the part number which is AM52375. That # translates to 18000510 which is replaced with point # 025. I now know I have the right set of points in the machine.
Thanks for all the imput. Now back to seeing if I can get it to idle.
Joe
Joe
I am back to dealing with the lack of idle. The only way I can get it to idle is by having the high speed needle closed or just open slightly. I have adjusted & adjusted this carb with the same results every time. The only other thing I can think of is the seats for the needles are so wore out that you just can't tune this carb.
I need to try a different carb to see it it does the same thing.
Is there anything else I am missing??????
Joe
Joe
Update!
Took carb apart again. Cleaned everything with brake cleaner & cleaned & checked all ports. Looked over all gaskets & dia's & everything looks good. Checked springs & valves, everything looks good. Adjusted the metering lever within specs.
Put the carb back on set the lDM at one open & HSM at 7/8 open. Machine ran good & idled good at 2400 RPM. I let it run for a good 20 minutes. I also turned it off & on several times. I also disconnected the electrical & ran it that way- ran good. Thought I had it figured out, so I started puting some things back on.
I put another sping on the muffler & installed the starter. Figured I would try it again, so I did.
BACK TO NOT IDLEING & WANTS TO BOG OUT!
I DON'T KNOW WHAT TO DO NEXT - DO ANY OF YOU????
Joe
Joe
- Danzig
- Real Name: Paul File
Does this machine have a new gas tank? If you are running a used tank, get yourself a flashlight and mirror. Check the topside inside of the tank for rust right in the areas around the red cap and the gauge. I had mine clean...
So I thought, the bottom looked brand new, however the top was the issue. The rust I had was like a cloud in the sky. Very hard to see, but when the engine died the fuel backed itself out of the fuel filter (running back to the tank) that is when I saw this rust cloud come out of my fuel filter. ITS VERY HARD TO SEE.
No it is the original tank. I did however remove it & used the oven cleaner method several times to clean it. The tank looked spotless of rust when I put it back in the machine. I did try running the machine out of a different gas can with the same results.
Joe
Joe
- Danzig
How about the fuel filter, have you changed it and ran it out of another container?
Could the exhaust be restricted or plugged? You said yo put the springs on and the problem returned.....
Todd
Todd
All the fuel line, inline filter & check valve in the tank are brand new.
As for the exhaust, I took it all apart & cleaned the inside and out with brake cleaner. I used an entire can of cleaner on the muffler before it started coming out not black. I used air compressor to blow air through it. I also ran it with the muffler off - still bogs & then dies.
Is there a way to check for muffler restriction other than what I have done??
I just checked the impulse PSI before it died out & it seemed good and strong.
I did check the upper half of the tank. When I cleaned it I cleaned the entire tank. It now DOES have some surface rust so I will try another tank with new gas.
This motor seems to have a mind of its own. I really appreicate all the insight you folks are providing!! I will check fuel system & provide an update.
Joe
Joe
- Danzig
Put a fuel filter on it for the fun of it...give it a shot!
