Liquidator
Liquidator
Holy crap what a haul! Don't worry about the pictures, I'll just come over and pick up all the sleds and take pictures here and post them for you. Oh... and by the way I'm Mike Hunt and I take pictures for Sno-pro magazine, so your sleds are safe with me. Especially that Dator. :ph43r:
Try shrinking your pictures first.
That has to be the find of the year for 2008! So technically we have found a $50 Liquidator.
:blink:
:blink:
1978 340 CC Liquifire
Liquidator
Are you related to ChickenRat? I think you both have horseshoes stuck you know where.
:o
:o
Liquidator
This is an awful good start to 2008, I just hope I'm not using all of my luck up for the rest of the year!
Liquidator
Good find! What part of the country are you in?
Liquidator
Bulldog my father in law has a 29 model A and that is nicest driving car I have ever driven! Can you post some pictures of yours in summer fun?
Liquidator
I'm in Ohio. This did not work as I had planned, but here is a link to some pics of the dator www.msnusers.com/jdsleds. Sorry for the inconvenience, but I'll try to get the pics on here.
Liquidator
if you click on the link below you will see a dator motor with a water hose coming from below the fuel pump. when i get all my dators done ill put them on this site.
ted
ted
Ted
3 Liquidators
1-340/S
1-295/S
1-78 Cross Country Liquifire
Ted
3 Liquidators
1-340/S
1-295/S
Liquidator
Thanks Dator76! I'll assume that your other dators have the stock motor in them? Is the 340 dator motor a mean runner?
Liquidator
they pull very hard, lots of torque high in the power band a dator motor has about 65 hp same as a 440 liquifire. but a 440 liquifire motor is more of a work horse with a wide powerband throughout the entire rpm range while the dator motor is a more narrow band with a lot more torque in the narrow area high in the rpm range
this is one of the reasons the liquifire motor is a more rideable unit, and a race motor likes more attention...
the motor in that dator is the stock motor i cant find a pic of the one with the liquifire motor but ill try to take one tomorrow. the way to tell is by the hump on top of the head hump=liquifire.l
Ted
3 Liquidators
1-340/S
1-295/S
Ted
3 Liquidators
1-340/S
1-295/S
Liquidator
Yeah, I could see where the trail motor would be friendlier then the race motor. Dator76, do the 77&78 liquifire motors have the same belt driven water pumps as the 76 dator and liquifires?
Liquidator
Jag,
The 76-78 LF use the same water pump. The Dator has it's own unique unit with a different pully and housing.
Rich,
My 2nd Dator came with a stock 440 LF motor and 78 heat exchanger already mounted in it. I kept the parts in case I ever want to make a rider. I do have a Dator motor for it now, but the darn sled really needs a total resto.
When I first saw the 78 heat exchanger, I thought it was kind of a hack. Come find out years later it was acutally a pretty good idea...
Later Liquidator,
-Rainville
PS: Ted, nice to see you are still around and still with us...
Rich,
Later Liquidator,
-Rainville
Liquidator
as i remember a dator water pump is only slightly different with 1 fitting and the pully needing to be changed. but without them sitting in front of me i cant say for sure
Ted
3 Liquidators
1-340/S
1-295/S
Ted
3 Liquidators
1-340/S
1-295/S
Liquidator
Jagsf6
I'm in Ohio also.
where at?
I'll let you come over and look at my Dator if you want. I will try to help you out all I can, I will learn from you also.
Hee Hee
:ph43r:
GRP
I'm in Ohio also.
where at?
Hee Hee
:ph43r:
GRP
Liquidator
Rich,
You make me laugh!
GRP
You make me laugh!
GRP
