if you guys have a book (central snowmobile) take a look, maybe you can find it on the web
i want a puller that will work on both my trail and sportfire sled
look under kawa
cp-1146- $12.95 is that going to work on both the trailfires and sportfires and wut else
and under comet, all comet artic, *CP-2224 102C AND 108c plus 108 exp thru 95 -is this something special
the 12.95 sounds cheap which is the one i need if any??
thanks dustin
clutch puller
clutch puller
clutch puller
The puller I bought for my Polaris models w/ Fuji engines uses the same puller as my Trailfire and JDX...FYI
clutch puller
which one is that
clutch puller
You need to order a Comet puller.
That 1146 is not what you want.
Todd
Todd
