Mornin guys,
In the tech section when I ckick on the 1975 wiring diagram link it comes up as the 1976 diagram. Are they the same for both years?
Thanks for the help.
Later,
1975 wiring Diagram in tech section
Depends what sled you are working on - if JDX8/800 with CDI, the 1976 should be close, if you are working on points ignition model use the '74.
Actually, the 295/S diagram is probably closer to the JDX8/800. I don't know why I have that link pointing to the '76 one.
We are working on a 400, so will use the 74 scheme.
