rupp starts hard
rupp starts hard
i have a rupp that wants to start hard, let it warm up it will start again easy, it will want to cut out when accelerating, let off and try again and then you get all kinds of power tell you let off again, is this the points thanks dustin
rupp starts hard
sprayed starting fluid in the piston, fired right up, if i dont do that it starts hard??
and it will want to cut out, seem likes the points, but i dont know if that can be start up issues to??
rupp starts hard
A fuel problem maybe?
Starts on fluid, won't stay running.
Check carb, lines , filter, shutoff valve, ect.
rupp starts hard
it will stay running, just seems to loose its prime
rupp starts hard
I would say the comp. is low. Rering it for 18$ and you will be surprised.
