jd ignition tester
wgrdafoe
jd ignition tester
Post by wgrdafoe »
Does anyone have the test specs from jd for Kioritz cdi , i have a dva meter and would like to compare the readings.
jd ignition tester
The testing procedure is outlined in the JD service manual. The specs only relate to the JDM-74 tester. Check out this link...
http://z12.invisionfree.com/jdsleds/index.php?showtopic=491
wgrdafoe
jd ignition tester
Post by wgrdafoe »
I thought the jd tester was just a peak volt meter checking voltage out puts from the stator and cdi. i checked the cdi output to coils approx 150 volts,this is close to most cdi voltages.
