Carb cleaning
79 Deere
Carb cleaning
Post by 79 Deere »
Been trying to get 2 carbs cleaned for sometime now. I have soaked them many times in carb cleaner, Sprayed and blown the heck out of them with no luck. My only problem is getting the air passage way from rear of carb to the pilot jet clean.It seems it is open until it gets to the bend near pilot jet. I was thinking of putting them in a pot of boiling water then try to blow out passage way(only when the wife goes out of course). What do you think, will it help or will it hurt the casting or is there an easier way to do this.
jerryswiss
Carb cleaning
Post by jerryswiss »
By the lack of response, I guess that means noboby knows. I don't know, I have never tried it. I do think the idea of heat is a good idea.
What are you soaking in in now? Are you doing it in the garage or the house? I know if you keep the soaking liquid warm it helps.
79 Deere
Carb cleaning
Post by 79 Deere »
I am using gunk carb cleaner in a 1 or so gallon can , 2+2 in a spray can then using compressed air.I have never had a carbs this clogged in the hardest place to get at. I just came in from the shed with no luck tonight. I think the air passage is clogged where the little brass fitting is pressed in at the pilot jet.These things have been sitting for about 18 years or so but this is getting very frustrating. Never thought that this would be the hardest thing to do considering I rebuilt the motor and replaced everything else with no problems.
jhecht
Carb cleaning
Post by jhecht »
I have the same problem with a carb on one of my 440s, im still trying to figure out how to clean it as well... I tried the gunk and the air compressor trick with no success... I thought about boiling it as well, I know my uncle who owns a restoration shop said he's done it before but I still have my doubts. I should also mention that i have the sleds inside a heated shop so its not like the cleaners are freezing
79 Deere
Carb cleaning
Post by 79 Deere »
The only reason I am thinking about boiling them in water is I used to work at a transmission shop and we had a big machine we would put all the tranny parts in and it would steam them and they would come out like brand new.The only draw back is if you boil the carb the crap in the the passage way might even get harder.I still have a trailfire carb in the shed I use as a paper weight cause It had the same problem, I had to get another carb after that and I might have to get 2 more now.I now have them on the workbench with 2+2 sitting in the holes, maybe over night the carb ferry will let them drain out the other side and I can finally hear this thing run...
Danzig
Real Name: Paul File
Carb cleaning
Post by Danzig »
phosphoric acid, I dont know where to buy this though.
79 Deere
Carb cleaning
Post by 79 Deere »
maybe ill get it from the neighborhood dealer...LOL I will try that...thanks
Danzig
Carb cleaning
Post by Danzig »
Caution when using this stuff. I used it before and did a dilution of 1 gallon acid to 2 gallons water. It will bite!
Danzig
Carb cleaning
Post by Danzig »
It made this carb look like new and this carb is in use today.
79 Deere
Carb cleaning
Post by 79 Deere »
Thats not the stuff they use to clean beer taps, I have some , but I just did a search it comes in fertilizer
Danzig
Carb cleaning
Post by Danzig »
At work we have a machine called a Thermal Deburr. This machine blasts cast iron castings using natural gas and oxygen and a spark. After that operation the parts or castings are rusty and we use this in a wash tank to remove the rust. I have also used this stuff in the gas tank of my X8 and it came out looking brand new.
Danzig
Carb cleaning
Post by Danzig »
The product comes from a company called Quaker
79 Deere
Carb cleaning
Post by 79 Deere »
do you think that would eat the crude out of the passage way.
Danzig
Carb cleaning
Post by Danzig »
Danzig
Carb cleaning
Post by Danzig »
Yeah, it will eat up basically anything in due time. Even the carb, therefore its best to dilute it and keep an eye on it. I soaked this carb for about 3 hours and it came out like new.
