chain case lube
larky
chain case lube
Post by larky »
I read the FAQ about chain case lube, and how SAE 30 is what is recommended. but was wanting some opinions on using 10W 30 motor oil. My thought was it could be better at lower temps with its reverse viscosity.
Any info is greatly appreciated
GreenSpeed
chain case lube
Post by GreenSpeed »
I've used 10W 30 and it seems to work well at low temps.
-John
KennyH
chain case lube
Post by KennyH »
I use ATF in mine, haven't had any trouble with it.
Later,
