diffrences between 440 a and b
kansasen
Post by kansasen »
did they just change the heads for more compression and more agresive jetting to get more h/p on the sportfires than on the trails
Liquifire84
Post by Liquifire84 »
There is more to it than that. The bottom end is where all the differences are at. The sport has a beefier crank than the trail.
Brice
kansasen
Post by kansasen »
what if you put the B model heads on an A
Liquifire84
You wont get any thing from it.
Brice
kansasen
Post by kansasen »
Then where do they get the extra H/P from cause a beefer crank isnt going to make mere power heavier crank will give more ineritia there has to be more compression or more flow in the engine the pipes and the intakes look the same and the same size carb
Liquifire84
The cyclinders are differnt than the trails.
Brice
Liquifire84
They also had differnt carb. They had a PJ on the sport.
Brice
kansasen
Post by kansasen »
shorter deck height or diffrent piston? more compression?
Liquifire84
They used the same piston. Differnt jugs, differnt base, bigger crank, bigger main bearings, differnt intake, differnt head, bigger carb with PJ. These all add up to the 8 more HP. just a little of everything makes an improvement.
Brice
