Liquifire motor in a Liquidator
I haven't been able to find a Liquidator motor yet, but I have a 76 Liquifire motor that I have been thinking of putting in my Dator. While I was at it, I was thinking of getting it bored and ported. Would these mods make any difference or would I just be wasting my money?
good idea, that motor and parts for it are as rare as hens teeth. this will give you a chance to ride it without worrying, about the engine at least.
Yeah I know! I was just wondering if a port and bore job would be worth it, or if I would be better off running the stock 440.
I would keep it stock. A bore job is only used to correct worn cylinder walls. Even if it was bored out to 0.040( the largest oversize), the horsepower gains would be minimal. Porting should only be left to the experts and will be costly.
Freshen up the motor(check bore, hone cylinder, re-ring) . If you have the dator exhuast pipes, that would make a difference from the stock liquifire exhaust.
I personally wouldn't mind having a Liquidator chassis with a Liquifire motor in it. No worries to drive, parts are easy to find, & 99% of the world would never know anyway. Keep it simple and you won't be disappointed.....
Robb
Robb
Thanks for all of the replies. Is there any particular place that sells qaulity bearings and seals for the bottom and top end?
- Horicon Joe
- Real Name: Joe Wanie
If you use the dator pipes, you will have to cut them to make them fit ....... Not worth that in my opinion .......
Joe
Joe
I have a better idea, I will trade you a sprintfire that is in showroom shape for the dater.
Hmm,,, just a thought.
GRP
GRP
Hey, that's my Sprint!!!
Robb
Robb
WAS!
Now Robb, you have to get a hold of your self, things that are no longer yours are no longer yours......
Hee Hee,,,,,
I have finally gotten some good sleds and I'm proud of it! (Thanks to you for one)
Now find me a throttle cable for the Dator and a 100 MPH speedo!
Looks like your doing well.
Gary
Hee Hee,,,,,
Gary
afponiky I still have that cyclone chassis, it is a great candidate for a Liquidator motor. After you talked Rob down on the Sprint you got way to good of a deal to let that go. You got it less than what he paid for it. TASKY
AND,,,,,,
When can I pick it up?
B)
Let me know about your thoughts on that one.
GRP
B)
GRP
You sure you dont want it delivered? I will have to have cash first.
