Jetting with air box off
malone
Post by malone »
I put a kioritz 440 23/lc motor in a polaris indy, but I have no room for the air box. I guess I need to know if I need to bump up the main jets to run some k&n filters instead of the air box, I know it is a good idea to bump them up w/out the air box. but I dont know if filters do the same job as the air box. Or can I try to get rich enough out of the needle position. If anyone has some advise I could use it. Thanks
smitfire
Real Name: Dustin Smit
Post by smitfire »
hey, post some pics of the polaris jd sled
malone
Post by malone »
how do I get them on here?
malone
Post by malone »
PoDeere
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
You sure that the motor is out of a 76 440 LF? Motor looks different than mine.
Scott
malone
Post by malone »
More pics
malone
Post by malone »
Yeah I have had the sled for about 12 years now, it was mint when I got it it is a kec 440 23/lc I have went through it all when I was about 14 and put some chevy orange paint on it. but yeah I have had to order all sorts of parts and have delt with almost every thing where I woul have to know the exact motor.
malone
Post by malone »
Here is some of the tunnel
malone
Post by malone »
PoDeere: I do still need some advise on the jetting ? thanks
S_Kyle
Post by S_Kyle »
Just wondering, the orange paint threw me.
malone
Post by malone »
One of thoes child hood things; Paint anything you can get it to stick to.
If you use the K&N filters I would go up a couple of sizes & do some testing you may find out that you will end up leaner in the end than you are now as the K&N filters might not pull as much air as the OEM air box. but if you run no filters then I would start out about 4-6 richer & then do testing..
malone
Post by malone »
I am running 220 mains so you say start 4-6 up from that. so 260 +.thats w/out any filter or air box which makes cense to me. If the filters dont pull as much air as the box wont that make it a richer ratio. so if I am thinking right with filters I would have to lean in out, right? Maybe work that out in the needle position.?? I dont really know. I guess I should just get what I am going to get for it. Leave it alone and do a plug chop to see where it is at huh???
If running K&N's I would still start out a little rich then work leaner, don't want to burn her down & not learn anything about how to jet the first time out, right?
malone
Post by malone »
yeah You are right. I just thought that there would not be much difference between filters and an air box. enough that I could compensate either way rich/lean . with the needle valve. I will go spend the thirty bucks on some jetts. should I be worried about lean mix through the low middle range too?
