How much internal clearance between the aluminum pivot shafts and the swing arm tubes is acceptable.
78 Cylone Rear Ssuspension
Harley, if you use steel shafts you could get by with less clearance & add a grease zerk or 2 to the swing arm, I'm not so fond of alum shafts, to me that seem to stick easier than steel when they get dry & oxidizes. I feel there isn't enough weight savings too use them rather than steel for strength.
Just my $.0675 worth
Kenny, suprisingly I was able to remove all the aluminum shafts without any difficulty. I have to replace 1 that is badly worn(front swing arm). I noticed there is about 1/32 or less clearance in both swing arms.
Pat I see your getting into the new cyclone hows the x8 coming?
Andy,
To tell you the truth, I kave placed the X8 on the back-burner for now. I am concentrating on the 78 cyclone.
