3-in-1 Two clutch and on cooling
Deleted User
Post by Deleted User »
Ok here's my next set of uncertainty
1 - My KEC-400 is fan cooled, but I don't have the fan cover/ducking
2 - I need to get the proper belt for my setup the primary clutch has a ~3" gap between sides
and the secondary clutch ~1" when closed
what kinda belt showed I get ?
3 - I'm also not sure how to line up the two clutches ? any help here would be great
Thanks in advance
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
It would be more help if you could give model for the clutches, and since you are changing the motor the distances might not be the same. When I converted the clutch on my merc to a 100c I took it to a friends repair shop and he found one that would work with my odd setup.
Why don't you post a picture of the engine so it is more clear what you have to work with.
Shrouding pieces are out there as are the fan covers.
Deleted User
I finally got the secondary clutch apart is was completely seized.
Lot's of wd-40 lots of heat and light tapping and prying did the trick
I checked every where for a model / part # no go.
I found a site that says it's a Salsbury clutch
FYI it and Honda odyssey fl-250
Deleted User
found this on the net
D/S Sals. Drive 700 clutch
D/S Sals. Driven 790 clutch 1 1/4"belt The diameter is 1 1/2"
