Liquifire 340
Liquifire 340
What MM are the carbs on a 76 liquifire 340 and are they Zinc? I cant seem to find this information anyware.
Liquifire 340
34mm mikuni
Liquifire 340
The material is what is know as diecast or potmetal.
Yes there is zinc in it but what percentage I do not know.
Any metalurgists out there?
Liquifire 340
OK thanks guys i am just trying to figure out what rebuild kit i need to buy
Liquifire 340
Why do you need a rebuild kit? Almost every Mikuni I have ever seen can just be cleaned and reassembled. Are you missing pieces?
Scott
Scott
Liquifire 340
The seals are junk and the needle and seat need to be replaced also they are the cause of a flooding problem. i have cleaned the heck out of these but its time to do a little more than cleaning
Liquifire 340
When I went to get carb kits for the Cyclones, the dealer asked the same thing. Are the carbs Zinc or Aluminum? How does one know? Don
Liquifire 340
I believe it has to do with the slides there are heavy zinc/chrome & then there are the light aluminum ones. What that has to do with the carb kits I have know Idea???
Liquifire 340
Good question, but I thought it was carb body material they were talking about. The mik's Deere used were all of the aluminum variety I believe. I am thinking the "zinc" carbs might be motorcycle?!
Not totally sure about that, need to do some digging...
-Rainville
B)
-Rainville
B)
Liquifire 340
Joe, I think maybe the other way around, as the ones I have here are all zinc, the Dator uses zinc for sure, I'm thinking the heavier zinc ones were used in the snowmobile carbs for more weight to return the throttle in cold weather??? at least that would sound reasonable???
Liquifire 340
Some of this has come up before.
I'm thinking the slides Deere used are chrome plated brass. They are silver on the sides, gold colored on top. Rich can confirm this I think.
As for the carb body material, all the ones I've messed with, I'd call aluminum.
Liquifire 340
The tech manual said the carb bodies for the sports were aluminum.
Scott
Scott
