How about the Sprintfire...?
cyclone crazy
Post by cyclone crazy »
I'm not familiar with a cast ring that is interchangeable with the Invader pistons, including early Kaw powered Cats. Other than the Sprint there is no other model to substitute the rings from. Jack [Guitar Dude] and I just went through this, the only cast bore Kaw in a 340, was a different bore size. We went through every option ever made. There is nothing to substitute. Matter of fact, it was actually easy because the only 340 cast bore was the early F/A Cats, different bore size. I take that back, the only cast bore other than the Sprint was the '73-'74 Eltigre F/A, it was a 400CC. There was never a Kaw 340 with a cast bore, other than the Sprint.
If there is an option out there, we couldnt find it. I'll run this question by Trucker he would be able to definately tell us if there was an option that we may have missed.
cyclone crazy
JoeRainville wrote: Hi Guys,
It has VERY little in common with the Sprintfire. But, the Sprintfire is in fact a compbination of T-1 and T-7 parts, plus unique block, crank, jugs and head.
Have fun guys,
-Joe Rainville
"Tech-Ed"
This info is right on the money. Other than sharing a bore size the Invader motor is completely different.
Deere Daze
Post by Deere Daze »
Gregs 100% right, your engine is running on borrowed time.The only other way around this problem is to find over sized pistons with rings for the invader.All over sized pistons were made to be used is cast bores and not in crome bores, but on the other hand you will have to get the cyl bored out.
cyclone crazy
Deere Daze wrote: Gregs 100% right, your engine is running on borrowed time.The only other way around this problem is to find over sized pistons with rings for the invader.All over sized pistons were made to be used is cast bores and not in crome bores, but on the other hand you will have to get the cyl bored out.
Ed is correct. These pistons are available .10 and .20 oversize, with an asterick that states "oversized pistons are for cast bore applications, not to be used with sleeves".
Trucker
Post by Trucker »
I don't now of anything off the shelf that you could use but there is the option of having the rings chromed to work in the cast bore.
jdsledwheelman
Post by jdsledwheelman »
You could have the cylinders chromed. But on a rebuild you probably bore the cylinders anyway. So with the over size Invader pistons the rings would not even be a problem.
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
80 spitfire x3, liquifire x2, sportfire
81 spitfire
82 sprintfire, spitfire, 340 trailfire x2
83 snowfire
84 sprintfire, snowfire, trailfire lx
jdsledwheelman
cyclone crazy wrote: Dan
I have a run of Sprint pistons being made they will be available in late June or early July. [/QUOTE]
Let me know when have pistons made. I would like a few sets stand., .10, .20, and .30. I don't need to rebuild yet but I want to stock parts for my 82, and 83 sprint.
Thanks, Nick
B)
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
swedefire
Post by swedefire »
I want a bunch of pistons too!
Let me know!
cyclone crazy
jdsledwheelman wrote: I have a run of Sprint pistons being made they will be available in late June or early July.
Thanks, Nick
B)
.10 and .30 are not available. I have .20 on the shelf ready to go - $60 each shipped.
cyclone crazy
swedefire wrote: I want a bunch of pistons too!
Let me know!
standard size - exact OEM reoplacements from Shamrock will be available late June or early July, I have .20 on hand.
robtan88
Post by robtan88 »
HI FELLOWS. I know where there is a complete, ready to drop in Sprint engine here in Ontario Canada. I have the guys phone number, honerable guy to deal with. I have seen this engine, nice and clean, looked through the intake and exhaust ports,and didn,t see a mark. Only needs you,re carb, and exhaust manifold. Also know the history of the engine. Needs $250. for it.
