JDX8 motor
S_Kyle
Real Name: Scott Kyle
JDX8 motor
Post by S_Kyle »
I picked up a 440 ccw motor on the weekend, it has no jugs just heads and the bottom end. A buddy has a JDX8 motor that needs redone but is i real bad shape. Can we use the jugs off of the JDX on a piston port bottom end? I will look tomorrow and see which motor I have. The JDX is a 74 if that helps.
Scott
JDX8 motor
Check the name plates as there were several engines used in the model.
Most parts will not interchange.
Greg has NOS Jugs for $90. Buy of a lifetime.
JDX8 motor
If you are talking about mating a piston port with a JDX reed valve motor - then no, the cylinder design is completely different.
S_Kyle
JDX8 motor
Post by S_Kyle »
Good to know. Thanks
Scott
