I picked up a 440 ccw motor on the weekend, it has no jugs just heads and the bottom end. A buddy has a JDX8 motor that needs redone but is i real bad shape. Can we use the jugs off of the JDX on a piston port bottom end? I will look tomorrow and see which motor I have. The JDX is a 74 if that helps.
Scott
JDX8 motor
JDX8 motor
JDX8 motor
Check the name plates as there were several engines used in the model.
Most parts will not interchange.
Greg has NOS Jugs for $90. Buy of a lifetime.
JDX8 motor
If you are talking about mating a piston port with a JDX reed valve motor - then no, the cylinder design is completely different.
JDX8 motor
Good to know. Thanks
Scott
Scott
