Crank ID help needed
I was digging through a box of NOS parts that I got a while back and found a NOS CCW twin crank. But it has a 25mm taper output. What in the would is that for?
- JDXspec
- Real Name: Dustin
I believe the 72 model (400 & 500) Deeres used the 25 mm taper and only one pto side bearing which would be the 340-440/4?
That may be what it is than. 25/62/10 seal both ends, single bearing both ends with 18MM rod ends.
It was only wrapped in paper so I had no tag or part number. Thanks for the info.
