Liquidator resurection
That isn't as easy of a question to answer as it seems, if it's a cold day & your going into the wind It probably won't take as much speed, a warm day, tacky snow, hard pull, & you might have to get up to 50 mph + to keep it cool. I remember in ND that we had a wind from behind & we were kind of running in a vacuum & even running on the roads at high speeds they were getting real hot, a lot of guys started ripping off there hoods, which shortly after came the rule that you had to finish the race with your hood or at least a good portion of it..
Once my Dad started trail riding it he started having heating problems, & once the 78's came out with the tunnel cooler & we could get our hands on one he installed it & never had any problems again..
Except when I rode it one time in the vintage 76 & older race in Garrison MN. & I stopped in a big water puddle to refuel & it froze the tunnel cooler in ice. he didn't tell me all I had to do was shut the motor down for a couple of minutes & the ice would melt off, until later????.... That was the only race I had a chance of placing high in ( there wasn't much competition in that class at that time) & I left the sled sit out on the ice & walked away :doh: , because I didn't want to burn it down?? ( a good racer wouldn't have cared if it burnt down or not, but being it was the old mans sled????)....& didn't know that was all that the problem was.... If only I didn't know now what I didn't know then!!!!!
I believe that IF it would have been a 80+ cooler that wouldn't have happened.. but that was in the early spring of 79.
Install the tunnel cooler it will be well worth your time later in $$$$ & headaches saved
_FIII
Post by _FIII »
so, how should it be plumbed? To the rad or heat exchanger first? Has this been discussed before and if so, who has done it? I would like to see some pics and get some suggestions.
Richard Gehl
Regina,Sk
I'll have to have my #2 son take some pics & let me know which it's plumbed to first, he has the sled at his place.. email me direct & I'll send you the pictures direct as I can't seem to post them here, ( Operator error ), LOL
ump45-nt@swbell.net
_FIII
Post by _FIII »
skis are all fixed up and painted. Waiting for carbides and shocks. The hood was cleaned up and put back on with a new windshield.
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10195.jpg
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10196.jpg
Richard Gehl
Regina,Sk
Jack Frost
Post by Jack Frost »
Richard the sled is looking real nice! :clap: I'm green with envy. :lol22:
Dave
1978 340 CC Liquifire
_FIII
Post by _FIII »
thanks Dave. I can't wait for snow!
Richard Gehl
Regina,Sk
_FIII
Post by _FIII »
this is from Friday. Rear skid was disassembled and it was not easy. A lot of heat and swearing, but it all came apart.
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10198.jpg
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10202.jpg
Richard Gehl
Regina,Sk
_FIII
Post by _FIII »
After a few hours of sandblasting on Saturday, some cracks were found and this is the result. Some scrap 11ga. steel and some tig welding.
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10206.jpg
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10205.jpg
Richard Gehl
Regina,Sk
_FIII
Post by _FIII »
today the rear skid was assembled with all new bearings in the wheels and new sliders. A couple of the cross shafts had to be remade and grease nipples were added in those pivot spots.
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10208.jpg
Here she is sitting on her own for the first time in months.
http://i272.photobucket.com/albums/jj167/_FIII/Sleds/John%20Deere/SDC10209.jpg
Richard Gehl
Regina,Sk
Lookn good Rich, Did you decide to put in the front tunnel cooler??
_FIII
Post by _FIII »
Well I already had the drive shaft and track put in, so I am going to run it like this for now and will put it in later. Had I remembered before the drive shaft and chaincase was reinstalled, then it would have one for sure.
Richard Gehl
Regina,Sk
_FIII
Post by _FIII »
Good day yesterday. The dator moved under its own steam for the first time since the early 80's. No video as I was by myself. The clutch set up is rank on this thing, engagement is north of 5500 rpm. I also noticed that the rear holes for the rear suspension were moved back, which resulted in the rear susp being sucked up. The machine sat real low like this. I will have a few more questions now for the original owner.
All ready for snow now fellas!!!!
Richard Gehl
Regina,Sk
Rich, I hadn't noticed before but if you have 2 extra small wheels add them to the appropriate place on the outside of the suspension, Between the front & rear springs. It will help roll the track easier & save on Hi-fax..
_FIII
Post by _FIII »
Kenny, those wheels were re-installed after I took the pics. I left them out so that I could adjust the spring tension easier and I was waiting for two more bearings as well.
Richard Gehl
Regina,Sk
Danzig
Real Name: Paul File
Post by Danzig »
Has this sled seen snow yet this year?
