73 X8 Carb
73 X8 Carb
My 73 jdx8 had three carbs in the box...WDA30/31/34.
Which one is the corrct carb or did they come with different ones?
HoosierDeereMan
Real Name: Troy Miley
73 X8 Carb
Post by HoosierDeereMan »
Todd,
The WDA-34 is the correct carburetor for a '73 JDX ser# -20,000. If your luck is like mine it will take all 3 to make one good one. Worn throttle shafts are the demise of most of them. Broken metering plate screws run a close second. If it turns out your WDA-34 can't be salvaged you can upgrade to the WRA-31 for better mileage and performance.
73 X8 Carb
When I took the 34 apart it was a nightmare inside so I will be using a 31.
Previous onwer may have planned to do this as the sled came with all three carbs.
Thanks for the reply.
Danzig
Real Name: Paul File
73 X8 Carb
Post by Danzig »
Good luck Todd....Many moons were seen rise and fall doing mine...
:sick:
Get a BFH and a case of Bud light for this mission.. :popcorn:
