Cyclone
427cobra
Real Name: Eric
Cyclone
Post by 427cobra »
Well I am getting closer to completing the Cyclone. However the key and kill switch will not turn the sled off. It continues to get spark no matter what... :boohoo:
I know its the usually the other way around....trying to get spark....ha
What should I be checking? It would be nice to be able to turn the sled off when I try to start it... :lol22:
Thanks!
PS
When I got the sled it looked like it had switch wired in to kill the engine. I also noticed that a white wire is cut....hmmmm :doh:
JDXspec
Real Name: Dustin
Cyclone
Post by JDXspec »
The white wire is the kill wire. (It should go to the cdi box) Ground that it should lose spark. :pray: if that works connect that to the key and kill switch.
427cobra
Real Name: Eric
Cyclone
Post by 427cobra »
I will check that out tonight! It was cut after it comes out of the engine and the spade connector was also cut off. So I will have some splicing to do!
427cobra
Real Name: Eric
Cyclone
Post by 427cobra »
Some white wire, solder, and heat shrink....now everything works as it should.... :dance:
Thanks!!
Cyclone
Eric, we had the exact same problem on Cyclone #1. Bob did exactly what you did and it worked!! DA
427cobra
Real Name: Eric
Cyclone
Post by 427cobra »
Don,
I figured it had to be a simple fix. I bought the wire at Menards and they only had 100' rolls. But it was only around $7. Now I have some extra white wire..ha
Looks like everyone had a good time at Haydays.
