440/5
redneckchicken
440/5
Post by redneckchicken »
what did this engine come stock in I have an 74 jdx8 with this engine in it and am trying to get the right freakin points for it
'74 and later 500 and 600.
JDXspec
Real Name: Dustin
Post by JDXspec »
The 74 JDX8 would have a 440/22 reed valve eng in it. The 74 and up 500 and 600 used the 440/5 which is piston ported
JDXspec
Real Name: Dustin
Post by JDXspec »
According to the SM the 440/5 should have a Denso magneto. It looks like that Denso was also used in the reed valve eng used in the JDX8 so maybe they use the same points? Hope this helps
440/5
The flywheel may be marked "ND" ( nippondenso )
Also, I believe the Denso flywheel will have the magnets embedded in the ring.
The Kokusan flywheel looks like the magnets are stuck on inside the rim.
I'm attaching a photo of a Denso flywheel ( inside view ).
JDFanPa
Post by JDFanPa »
funny thing my 73 x8 has the same incorrect engine installed the green motor mount is a big give away lol
