JD 300 Engine Rebuild
DLDeere
Real Name: Howard Olson
Post by DLDeere »
I opened up a stuck Kohler 295 engine from a 1975 JD 300. There was water standing in the bottom of the crankcase and one of the crankshaft bearings is stuck. The other bearings are rough and the connecting rod bearings are rough. I see that Central Snowmobiles does a crankshaft rebuild for $175 plus parts. Is that what I'm looking at to get this crankshaft repaired?
Another idea is that I have a CCW 440 from a 1973 JDX8. Since the chassis is so similar, I wonder if I could put that in the JD 300? Any thoughts on putting the bigger engine into the 300?
Howard
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Howard,
We actually have a crankshaft pro sponsoring the site, and his rate is less then Central's.
http://www.jdsleds.com/ads/cs.html
You may also want to check around for NOS crank, they seem to be fairly common for the Kohler.
Central closed their machine shop, so that is out.
Go NOS or talk to Jerome.
If things are really rusty, I'd go NOS.
A 340 or 440 will fit, if you change out the motor mount/ hoop, and both clutches.
DLDeere
Post by DLDeere »
Thanks for the info! I've found an NOS, but I'll also check with Jerome tomorrow.
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
JDFanPa
Post by JDFanPa »
If things dont go through Ive got several good used kohler 295s that Id sell for $75 each plus shipping aswell as genuine kohler rings and gasket sets.
Hey Andy, you by any chance don't have a 67 Larson ( the one with duel headlights ) in that mess someplace do you??
DLDeere
Post by DLDeere »
Andy,
Where are you located?
Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
JDFanPa
Post by JDFanPa »
Sorry Kenny no larsons in the fleet and I dont know of any either. Howard I am in Scranton Pennasylvania.
