Seal Numbers Please
Seal Numbers Please
Central really changed their catalog and I can't find an old one. There are two "normal" seals used with the Kiortiz engine, the 1333 and 1302. What I can't find is the usage for each one. Thanks, DA
Seal Numbers Please
WinnipegStPaul9 wrote:Central really changed their catalog and I can't find an old one. There are two "normal" seals used with the Kiortiz engine, the 1333 and 1302. What I can't find is the usage for each one. Thanks, DA
Don,
Seal # 1333 is for the mag side oil seal and seal # 1302 is for the pto side seal for any of the Kioritz /22 engines.
1333 =M63541 SEAL (SUB M66694) 25 x 62 x 10 (ID x OD x WIDTH)
1302= M63683 SEAL (SUB M66555) 30 x 62 x 10 (ID x OD x WIDTH)
Last edited by harleysportster on Mon Oct 27, 2008 5:01 pm, edited 1 time in total.
Seal Numbers Please
Harley, Do you have the sizes for those 2 seals? That also might be helpful to post.. on your response post with the part numbers..
Seal Numbers Please
Check edited post for seal sizes.
Seal Numbers Please
Harley, thanks so much!!! DA
