seized engine
Hansy
seized engine
Post by Hansy »
I'm looking at buying a 75 JD 800 with a seized engine and was wondering if anybody could tell me approximately what it would cost to rebuild it. is there a complete overhaul kit or do you have to do everything separate?
seized engine
Hansy,
First, welcome aboard. A complete rebuild kit for your engine is not available, parts will have to purchased individually. You will need to dissesemble the engine to determine exactly what is wrong. Possible causes could include:
-rings rusted to cylinder walls
-rusted crank bearings
-broken piston
-jammed recoil
The most expensive to fix would be the crankshaft-around $200+
Pistons-$45
gasket kit-$30
Hansy
seized engine
Post by Hansy »
Where would the best place to get the needed parts any in Canada?
seized engine
I believe the vendors such as Dennis Kirk and Central would ship to Canada. Try giving Ed a call, he is in the process of rebuilding his Ebay store.
http://stores.ebay.com/Greensleds
JDFanPa
seized engine
Post by JDFanPa »
you biggest prob is to find out where its seized some lube down the plug holes and working the clutch back and forth may free it right up rings often stick when an old sled has sat along time deeres have alot of engine coverage and aslong as everything was inplace when it sat its probably not stuck to bad in my experiences
hardware440
seized engine
Post by hardware440 »
another place to buy parts is sun and snow in portage manitoba or recreational supply in saskewan
Hansy
seized engine
Post by Hansy »
thanks guy, that will work great seeing as my mom lives in regina, sask
Spitfire79
seized engine
Post by Spitfire79 »
Sun and Snow doesn't sell direct to public. Nice guys though and will help point you in the right direction
Jeff
Lockport, MB.
Gotta love a 2 stroke !
Hansy
seized engine
Post by Hansy »
what is the most common reason for an engine to seize up just from sitting?
seized engine
Snirt, mice urine, condensation, rust, dust.....
Stuck rings will do it alot.
Hansy
seized engine
Post by Hansy »
so would putting moovit or liquid wrench in the cylinders and letting it sit solve that problem or should i pull it apart and put new rings in and clean the cylinders?
seized engine
Sure let it soak for several days and then try to move it.
Hansy
seized engine
Post by Hansy »
Ok i will do that when i go and pick the sled up, After i get back from LA where my wife is having a brain tumor removed. :(
seized engine
Wow Hansy, that is a heavy burdon. Godspeed.
Hansy
seized engine
Post by Hansy »
yeah, i knew what to expect when i married her and i'm up to the task.
