I give up
- Danzig
- Real Name: Paul File
I give up
I thought I had my L-fire licked when it came to the exhaust leak at the ball socket. Nope..
New springs, nope..still leaks. Bend the loops back on the Y-pipe for a tighter seal to tighten springs..nope...still leaks.
Sled is now sitting with enough high temp silicone at the ball joint to make valve cover gaskets for 20 cars and 17 trucks. Been drying since 11 am this morning.
I give up
I have faith youll get it figured out!! I think mine leaks too. I wonder if it is even possible to have leak free connection????
I give up
Paul,
I'm assuming that you cleaned all the gas/oil residue with a degreaser such as a "brake cleaner".
I give up
I wonder if you couldn't try to modify a lead donut gasket from another sled to fit the deere? I know my ZR700 I had used a real nice one there and the gasket will form to the metal and take up any space. If you couldn't make one work, maybe try changing the exhaust manifold, maybe it would be a better fit?
I give up
Have you inspected everything real close to make sure there isn't a pin hole right next to the joint? just a thought....
Tim Kudla
73 JDX4
80 Spitfire
82 Trailfire 340
84 Trailfire 440
10 SnoPro 500
73 JDX4
80 Spitfire
82 Trailfire 340
84 Trailfire 440
10 SnoPro 500
- Danzig
I give up
The bottom of the ball and socket is where the leak is. My clean motor looks like salt and pepper.
I blame Rainville also!!
I give up
Heres an idea Paul I think the big reason for the leaks is wear on the socket and the ball. I bet if you know someone who melts lead for sinkers etc what you could do is dip the socket of the pipe in melted lead to line it maybe 1/16" thick or so it would make it leak proof. Maybe as an another option if you knew of an old time body man who did lead filling they could line the joint also this is just some thoughts off the top of my head.
- Danzig
I give up
Does the joint need movement is my question?
All exhaust components are mounted on the orange rubber pads and left loose at a minimum for movement. I could weld the union solid and loosen up the muffler mounts to body even more for engine twist under loads. Is this a good and practical statement or idea?
I give up
If you weld it solid I bet your running a chance of it cracking somewhere later on.
I give up
Just a thought. What if you took a piece of carbon fiber cloth, cut a strip, put high heat silicone on one side and glue it to the flange. Just fold a little excess over the "lip" and mate the 2 surfaces back together? I've used the stuff in muffler packing before and it holds up to heat.... I think it would take up some of the gap in your flange.
I give up
Steve is right, its probably my fault.SKNOWCAT wrote:I'd blame it on Rainville.
Steve T.
Since he is full of hot exhaust gas, he should deffinately have a fix for you then!
Really though, high temp RTV isn't a bad idea, but I think a "donut" gasket from a Cat might be a good idea too. Are you also sure the muffer isn't plugged with a mouse nest or something?
Good Luck,
-Rainville
