sportfire rear shock
Dennis Kirt sells a rear shock for a Liquifire, will this work on a 80 sportfire?
I found one on Ebay a while back and it works fine it is a Kimpex 114-14, it'
s measurements are 8" x 11 1/2". The bushings are larger but if you take the steel inserts out of the old shock the will fit just perfect in the new shock bushings. It should have that no. in some of the parts catalogs also. Mailman
Sorry I forgot to mention that I have a 81 Sportfire that I put it on. Mailman
I use a Kimpex 04-245 on both liq and sportfire,woks fine Deererunner.......
Thank you for your help. Timothy
