I just brought it home, not running. I know very little about these engines, but willing to learn. I've been reading the topics from the past on the site, they have given me an idea.
I put some gas in the carb and it fired up for a second or two until the starter cord broke, one more issue.
It has fuel in the fuel line, the fuel pump is not attached, would thart make any differance?
The wiring seems to be in order, but all over, and I have no idea what to look for. I know I need a manaul and a repair book for a dummie.
Any help or advice to get me started would be appreciated!
TL
80 spitfire
80 spitfire
Your best bet is to pull the carb and clean it. Might not be a bad idea to rebuild it along with the fuel pump. Drain all the old gas out of the tank. You should also put new fuel lines on. Once everything is hooked up, including your fuel pump, put some fresh premix in and she should fire.
1970 Wheel Horse 295
1980 Arctic Cat Jag
1989 Ski Doo Mach 1
1995 Arctic Cat Kitty Cat
1980 Arctic Cat Jag
1989 Ski Doo Mach 1
80 spitfire
You are going to have a fuel line from the tank to the filter and into the fuel pump and then one from the pump to the carb. You need to have one from the crank case to the fuel pump centre as well to power the pump. Depending on the mikuni you have you'll want to make sure the float works in the carb.
80 spitfire
thanks, should I consider rebuilding the motor too? Where do I find out what carb I have and fuel pump?
80 spitfire
http://www.vintagesnow.com/index.html Try this link for the manual online and reference material. He has a pretty good site. I tried to attach the manuals last night to the messages but it didn't work so here is this for ya'. I just bought the 78 Spitfire 340 Kohler for my second JD ride. I am waiting for parts right now or I would be riding. My first JD ride was stolen this year so I am Deere hunting until i get her back.
80 spitfire
mfgsupply.com has the fuel pump.
Look for "Mikuni, single" (it's the rectangular one).
Actually here:
mfgsupply #07-425 - Mikuni Type Single Fuel Pump
As for the carb kit, I need one too.
I haven't quite figured out how to order that one.
(I'm kinda hoping it'll show up here)
Actually here:
80 spitfire
My local dealer couldn't get me a complete kit for some reason. Had to get individual parts. Never did get the right gasket for the bowl. Had to end up buying gasket material and make my own. What a pain!
1980 Arctic Cat Jag
1989 Ski Doo Mach 1
1980 Arctic Cat Jag
1989 Ski Doo Mach 1
80 spitfire
thanks guys this all helps!! What about the starter rope and recoil?
80 spitfire
try ebay for your part needs
