1980 liquifire carb problem
xcr800
Post by xcr800 »
My friend just bought a liquifire the other day. We are having a problem removing the choke plunger assemblies. Is there a trick to this we have unscrewd the nut that holds the plunger assemblies in but they won't come out I think they are stuck
ralphy
Post by ralphy »
Soak with PB blaster, shoot some into the hole on the plunger side in the intake horn of the carb. If it doesnt come out after a day or 2 of soaking, you might have to resort to drilling them out, or replacing the carbs.
Soak the plungers overnight with your favorite quality penitrating oil.
Use a small standard screwdriver and very gingerly try and twist it back and forth.
Soak it again and twist more later. They will break loose eventuallty.
Then clean the plungers and inspect the seats very carefully.
Replace if they look bad.
xcr800
Post by xcr800 »
Thanks I will give it a try
DanzJD
Post by DanzJD »
Am having hard starting when cold,choke valves seem to work,cleaned carbs an rejeted to 150. An this machine has only 870 Km orig
