pics of the cylinder and piston on the PTO side of 80 trailfire. engine has new gaskets and seals, idled great ran fine and then down it went. is it just the age or what should i look for. didnt notice anything while jugswere off during rebuild but i guess i didnt look to close either any insite?
thanks
Joel
melt down
melt down
Which side of the piston is that intake or exhaust?
melt down
How tight is your fan belt?Looks to me like it was over heated.
melt down
It looks to me like the piston got burnt from lean mixture or severe detonation. I had a 6.5 turbo bus that did that to a pair of lungs 2 times. Active engine said it was lean out from the oil pressure sending unit trying to shut the engine down while the driver pushed it harder the ECM was cutting fuel to shut down. The flame wants to burn something and in low fuel lean out it gets super hot and will actually burn the piston. Anyone who has fooled with nitrous oxide has a set of pistons that look like this 'cause if they lean it at all it will burn down.
- Joliet Jake
melt down
I might jump in here and post:
I bet it wasn?t the a signal from the oil injection to the ELICTROIC CONTROL UNIT that the oil pressure wasn?t sufficient and this then resulted in the ECU sending a signal to lean out the fuel to that cylinder to shut it down and with that subsequent leaning of the mixture lasted long enough to result in the burn down.
But what the heck do I know
Sorry for being a wise ass!............looks like somehow that cylinder got very lean
Now the fun begins!
Now the fun begins!
72 300
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
