melt down
jdcrzy
melt down
Post by jdcrzy »
pics of the cylinder and piston on the PTO side of 80 trailfire. engine has new gaskets and seals, idled great ran fine and then down it went. is it just the age or what should i look for. didnt notice anything while jugswere off during rebuild but i guess i didnt look to close either :wall: any insite?
thanks
Joel
big danno 1970
melt down
Post by big danno 1970 »
Which side of the piston is that intake or exhaust?
jdcrzy
melt down
Post by jdcrzy »
exhaust side
big danno 1970
melt down
How tight is your fan belt?Looks to me like it was over heated.
jdcrzy
melt down
Post by jdcrzy »
new belt, tension good
jdcrzy
melt down
Post by jdcrzy »
after looking at slid found the needle all the way down, so probably running lean. will make adjustment when getting it started again. im runnung 40 : 1 premix will premium gas.
thanks
joel
Miller Motorsports
melt down
Post by Miller Motorsports »
It looks to me like the piston got burnt from lean mixture or severe detonation. I had a 6.5 turbo bus that did that to a pair of lungs 2 times. Active engine said it was lean out from the oil pressure sending unit trying to shut the engine down while the driver pushed it harder the ECM was cutting fuel to shut down. The flame wants to burn something and in low fuel lean out it gets super hot and will actually burn the piston. Anyone who has fooled with nitrous oxide has a set of pistons that look like this 'cause if they lean it at all it will burn down.
Joliet Jake
melt down
Post by Joliet Jake »
I might jump in here and post:
I bet it wasn?t the a signal from the oil injection to the ELICTROIC CONTROL UNIT that the oil pressure wasn?t sufficient and this then resulted in the ECU sending a signal to lean out the fuel to that cylinder to shut it down and with that subsequent leaning of the mixture lasted long enough to result in the burn down.
But what the heck do I know :lol22:
Sorry for being a wise ass!............looks like somehow that cylinder got very lean
Now the fun begins!
72 300
75 LIQUIFIRE
76 LIQUIFIRE
78 LIQUIFIRE
78 CYCLONE
80 TRAILFIRE
81 SRX
83 LIQUIFIRE
83 SPRINTFIRE
88 650 INDY
94 MACH Z
2000 MACH Z
2005 MACH Z
S 35 BONANZA
melt down
Could have been one of those super-mod Trailfires with 200 hp that were all dream about....
