plastic welding a tank
S_Kyle
Real Name: Scott Kyle
Post by S_Kyle »
Has anyone had luck plastic welding a sled tank together?
Scott
jdsledwheelman
Post by jdsledwheelman »
I don't know if that would hold up long maybe just get a different tank what sled is it for :?: :think:
nick :cool:
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
80 spitfire x3, liquifire x2, sportfire
81 spitfire
82 sprintfire, spitfire, 340 trailfire x2
83 snowfire
84 sprintfire, snowfire, trailfire lx
S_Kyle
Post by S_Kyle »
1976 295 Alouette Super Brute. I a looking for a friend. I was informed that almost all of them have cracked around the filler neck and in this case along the bottom. We were just thinking that this might be our last resort. There was a guy with a 340 parts sled in Carmen MB but I can't find his number :wall: . This sled is in A1 mint condition - ripped seat but we need to get this sled back on the trail. It is just a blast to ride, spends more time with the skies off the ground then on.
Deere Daze
Post by Deere Daze »
If you can post a pic of the tank I can look at a few wreakers around here for you. :canada: :usa:
S_Kyle
Post by S_Kyle »
Will do
jdjason
Post by jdjason »
i used stell weld on my old tank and even formed the neck to put gas gauge on it steel tank but i have used plastick weld two part epoxy from napa on oil tank and various other plastic plastic parts part number 765 2419 and 765 2420 as long as its cleaned, roughed up,and wiped clean again it should work, but if ed can find you a tank that would be even better. good luck
jd400 1973 running
jd800 1975 running
liquifier 440 1977 runn
sprintfire 340 1983 running
nitro 440 1973 rupp ????????
77 cyclone 440 basket case
working on resto 75 x8
Liquifire 4/6
Post by Liquifire 4/6 »
Scott.....there's a guy in Yorkton,SK that has a 74 440 Super Brute. He's been tryin to sell it for 2 yrs, but he likely still has it. Far as I know, the tank is OK. I know his last name is Flundra, but I'm not 100% certain of his first name. I'm thinking it's Jim......and if my guess is right, his number is 306-783-3597. He was asking a bit much for it when I spoke to him last winter....if he still has it, perhaps his price has come down. He'll probably tell you it has a new track.....but the track that's on it is a JD track, so it'll heat up within a few hundred feet.......the Super Brute tracks were dimensionally identical to the JD 300 & 400 tracks, but they had a coating of hifax-like material on the inside of the track to run against the steel slide rails. Just thought I'd mention that in case he tries to make a big deal about the sled having a new track.
Peter from Roblin, Manitoba
S_Kyle
Post by S_Kyle »
Thanks for the help guys. I have some family around Yorkton so I might head up there for a visit. Pete the super brute, track aside was the sled in decent shape? I will take a good look at the tank when I see him tomorrow.
Liquifire 4/6
S_Kyle wrote: Pete the super brute, track aside was the sled in decent shape?
The hood looked good. I think there were some cracks in the belly pan, but nothing very major. The seat was reupholstered and whoever did it knew what he was doing as it looked fantastic. The bumper end cap trim pieces were missing on both sides. The plastic tool box housing at the front of the seat had some internal cracking which wasn't visible until opening the lid. The taillight housing wasn't great. The tunnel was nice. I think the engine had some issues, but I can't remember what the prob was. If you're passing thru Roblin on your way to Yorkton, drop in.......you can reach me at 937-7685.
Liquifire 4/6
By the way, Scott.....if you need a hood, I have a couple useable ones kicking around.
In years past I have repaired many other mfgs plastic tanks by using this method. Clean tank thoroughly with soap and water inside and out and make sure there's no gas fumes in the tank. Grind a 1/2" rod to a point. It doesn't need to be sharp. Heat rod until it's red hot. Take the rod and make a furrow where the crack is, about 1/2 the thickness of the tank deep. This will be the hard part because I don't know if you can find these anymore. I used old clear plastic covers from 1 or 3 lb coffee cans. I'm not sure if anything uses clear plastic covers any more. I supposed you could use your wifes tupperware covers (LOL). Take and melt the covers and let the melted plastic drip into the furrow. I've never had any problems with these leaking afterwards. I'm sure that with today's technology, maybe there is something else that would work such as the epoxy they use to repair the plastic bumpers on cars today.
spitty
Post by spitty »
Hi guys you can buy plastic welding rods,bodyshop guys use them to repair plastic bumper covers etc. on todays cars.There are different kinds depending on the type of plastic you are working with, I know we can get them from Napa here in Canada. Spitty
Liquifire 4/6
Scott.....I'm not sure if you've found a tank for the Super Brute yet. But in case you haven't, I just got a lead on another Super Brute for sale. It's in Pilot Butte, SK and the guys name is Harvey Hill. I don't have his number, but he should be in the book. I haven't seen the sled. Maybe he has some misc parts for sale as well such as a decent tank?
AJ Sparko
Post by AJ Sparko »
I used to weld plastic auto interior pieces back together or fill holes that a previous owner drilled as part of a custom audio installation business. They actually make a "kit" but personally I thought it sucked for the money it cost and always used a soldering iron. Pretty much the same method as Kenny describes with putting a deep v-groove in the crack. Then I'd take a rod of the same type of plastic and use the iron to melt it and swirl/mix it into the surrounding area. Sand that down and using a small butane torch I'd level it all out.
S_Kyle
Post by S_Kyle »
Found one locally. The problem a kid took a sledge to the sled when he couldn't get it to run right. It is sitting on top of a rock pile, so I have to go take a look. Thanks for the help guys.
Scott
