trailfire
427cobra
Real Name: Eric
trailfire
Post by 427cobra »
your heads are not torqued down. take off the engine shroud and re torque the heads. you may want to install new head gaskets as well. run the sled and let it cool down. check the head bolt torque again before you install the shroud....
smitfire
Real Name: Dustin Smit
trailfire
Post by smitfire »
I was thinking all new gaskets?
smitfire
trailfire
Post by smitfire »
torn the engine down today, the base gaskets and head gaskets were leaking
smitfire
trailfire
Post by smitfire »
i got the engine rebuilt and put back in, still has the same bog after warm up, i tried a different carb, coil
im am not sure what to do... thanks
smitfire
trailfire
Post by smitfire »
any ideas?
wyiron
trailfire
Post by wyiron »
Try lowering the jet needle in the carb one notch. Because..... if it runs progressively worse as it warms up, it's getting too much fuel.
If this helps but doesn't fix you can try a smaller main jet.
How many turns out is your mixture screw?
-wyiron
smitfire
trailfire
Post by smitfire »
2.5 I think... What should it be?
fordmtrsp
trailfire
Post by fordmtrsp »
1 turn is what my book says
smitfire
trailfire
Post by smitfire »
ok ill look into that, what about a bad fuel pump??
liquifire_freak
trailfire
Post by liquifire_freak »
does the sled still start hard? and im having the same kinda problem with mine rite this second but mine doesnt run bad when its warmed up but now she wont go anywhere lol if i get mine fixed ill let u know what it was i dont know if were having the exact same problems or what.
smitfire
trailfire
Post by smitfire »
ya i would say mine does start hard,
smitfire
trailfire
Post by smitfire »
so i adjusted the air screw, that was out 3 turns and the tech manual says 1.5
is that what you guys are calling the mixture screw?
also i tryed lower the needle clip 1 spot
i also tryed a different fuel pump
took it out for a ride didnt change, came back in the shop and let it sit and idle then i reved to engagement and turned it off, gave it a pull and a backfire, did the same thing about 4 more times
any ideas??
smitfire
trailfire
Post by smitfire »
got a different carb on it again, other one was leaking
changed to another coil, nothing changed
i am wondering if its down in the stator, exciter coil? timing?
spark gets weaker after warm up, is that possible??
any help would be great, thanks
smitfire
trailfire
Post by smitfire »
I FIXED IT!!! it was the timming
runs perfect, thanks for all your tips
monte44
trailfire
Post by monte44 »
You said it was it the timing was the marks not lined up??
