sportfire
sportfire
JDT still wondering on that check value,
i am having trouble again,
i flip the choke on it fires and quickly dies, then it wont start with the choke on, the gas line is full of gas
pull about ten more times with no choke and it starts
sportfire
ok, so i still wonder if that is what i need or if its in my choke because today i didnt use the choke (cold engine) and in 1 pull it was running and stayed running, that is after sitting a day
a few days before i would flip the choke on and it would fire on the first pull but then i had to take the choke off and then give it ten pulls
any ideas?
any ideas?
sportfire
Sounds to me like it's being over-fueled. You are flooding it with the enrichener.
sportfire
so i lowered the choke plunger and it started in two pulls inside
let it outside for a couple of hours and i did regular choke for 2 pulls and then full choke for 2 pulls and then it started
normally you dont have to do you? full choke is for very cold temps
sportfire
full choke on first pull till it spit then regular choke inside or outside.
btw you probably need to fix your fuel pump.
Round slide miks have enough fuel in bowl to start and run an engine for about 30 secs to a min. if you dont have fuel in carb too do that, its usually because you didnt criss cross the vent lines on carb over the top.
