Scorpion sleds
malone
Scorpion sleds
Post by malone »
Does any one know anything about scorpion sleds. Reason I ask is I am going to pick up a scorpion sting 440 1980. Just kinda wondering what kind of motor it might have. were they good sleds??
Scorpion sleds
The Sting is a very good machine. Light, fast and excellent handling. Motor is a 440 Cuyuna.
malone
Scorpion sleds
Post by malone »
I think I have heard good things about that brand of engine? liquid or air cooled?
Scorpion sleds
Speaking of Scorpions, the Homecoming Reunion in Crosby MN is 4 weeks away. Who is going?
S_Kyle
Real Name: Scott Kyle
Scorpion sleds
Post by S_Kyle »
Would love to but I will be in that area a month to late to go. :wall:
smitfire
Real Name: Dustin Smit
Scorpion sleds
Post by smitfire »
they are fast
smitfire
Scorpion sleds
Post by smitfire »
they are fast
WatertownBob
Scorpion sleds
Post by WatertownBob »
My brotherinlaw had one. Not sure what model it was a 440 twin carbs Fan if remember right.
He kept burning up pto side piston. Make shure that the seals are good and clean carbs with proper jets.
Bob
malone
Scorpion sleds
Post by malone »
Got her home last night. Has single carb, 440 no spark. Going to try and clean points. Any other points of intrest I should check for spark problem. Never owned a sled with points ignition. Other than that sled is in real good shape, also need to find a windshield. any help would be greatly appreciated. oh yeah what ratio do I mix the gas at??
thanks,
Dave
malone
Scorpion sleds
Post by malone »
OK I need some help testing the ignition parts on this sting 440?? I really dont have much experience with points ignition. Before removing the flywheel I pulled it over while reading output on the wire supplying power to coil. I think it has some power but I dont know what it should read at just pulling it over. does any one know what kind of readings I should be getting, and procedures for testing ignition equipment, like what to test first and how.
Dave
S_Kyle
Scorpion sleds
Post by S_Kyle »
scorpsrus.com, they will have almost any NOS parts you need. I have been told they have decent prices also. Need to order some bits for my whirlwind
malone
Scorpion sleds
Post by malone »
Got into it and it has cdi Ignition; Should have looked a little closer. Wired in a different cdi box and coils, finally got spark. But it flooded itself extremely bad, I am talking gas spitting out of the exhaust. I am thinking a stuck float. Does this sound like it could be the problem??
S_Kyle
Scorpion sleds
Post by S_Kyle »
It is possible to check the float by inverting the carb and seeing if the float closes the jets off. It is worth a try, never hurts to check on your gut feeling
Scorpion sleds
Only Scorps that had CDI were 77 Bullwhip, 80-81 Sting and the 81 Sidewinder.
Walbro WF-1 carb needs to be throughly cleaned.
I am sure that Dennis would have a NOS windsheild for you.
Where did you find a CDI? they are very hard to land.
malone
Scorpion sleds
Post by malone »
the sled has a mikkuni butterfly carb on it. it was in NE Minneapolis on craigs list. I wired a cdi and coils off of a 76 liquifire. thats what is kinda funny about this thing. the owner swore up and down that the points needed to be cleaned. so i said sold because that should be an easy fix I thought. I looked under the hood only once the night I bought it to make sure everything was there. I went to dig in today and saw cdi. I had a massy furgisson snowmobile a while back that had the same engine as this sting I bought. The massey came with the walbro carb on it. but both engines and even the air box look identical???
