Scorpion sleds
Scorpion sleds
You got spark with a Presolite box on a nipondenso stator?
WOW! Never would have guessed that would have worked.
malone
Scorpion sleds
Post by malone »
took carb apart and everything was good but I cleaned it anyway, Stlii flooding really bad.. Going to try to let it sit wor a day or so to see if it will dry out and hopefully it will run. I hope, This little sled looks like it will be allot of fun. and it even took a few deere parts to get her to run.(Hopefully)
Scorpion sleds
Does yours have the the tunned pipe?
That was good for 56 HP if I remember right.
malone
Scorpion sleds
Post by malone »
it took a little thinking as to which wires went were but it was not too bad. I figured it was worth a try. It doesnt look like a tuned pipe it. nothing like a set on like a 80 kawi motor or anything it looks like a single stock pipe.
Scorpion sleds
There were two different exhausts used, both singles. One stock and the other the same as the TKX HP one.
malone
Scorpion sleds
Post by malone »
I guess I dont know what it is then. from what I have heard of it running it sounds like it will be pretty healthy. It seems like it gets so flooded that it cant stay running. I am also thinking maybe fuel pump.
S_Kyle
Real Name: Scott Kyle
Scorpion sleds
Post by S_Kyle »
What about an improperly jetted carb? If the last owner didn't know it was a CDI sled then maybe the mikuni was never re jetted for the sting, the carb might be giving to much fuel for the motor.
JDT, I believe that my whirlwinds have a "tuned" exhaust on them, was this the "pipe" or the standard or are they too old for that difference. 56 hp in those light sleds sounds like a lot of fun. Can't wait to get mine back and see what it can do. Also I was talking to my uncle after he herd about the Massey's and he mentioned that a friend of his had an 81 sidewinder. Would it be worth pursing in your opinion or were they not that special?
malone
Scorpion sleds
Post by malone »
I have the walbro and intake for the massey still maybe I will try to clean that up and try it. if that is what is supposed to be on that engine. that is what was in my massey. That old piece of **** was really fast. The bogies and track is what failed me..
malone
Scorpion sleds
Post by malone »
is anyone sure if the 1980 sting didn't come with a mikkuni. carb and a fuel pump are seperate, and the walbro has the pump mounted to it. the setup looks pretty factory to me
Scorpion sleds
I have one Massey Storm that has the HP pipe on it. My other Storm is missing the pipe .... and the engine. :(
I have a 80 Sting with the stock pipe. I sold the other one with the tunner many years ago. The buyer grass draged it.
The Sidewinder is just like an El tigre but it looks a lot sexier. They are bringing big bucks so if you can get it would be a sweet deal.
Couple of years ago I helped a guy fix up his Whirlwind. He had put twin carbs on it and some type of 2into1 performance exhaust on it. Maybe a hooker?
Had to remove one headlight to make it fit. It was nasty fast... nasty scary fast.
S_Kyle
Scorpion sleds
Post by S_Kyle »
Do you know the hp of a non power pipe 440 cuyuna.
Scorpion sleds
I just checked the 80 specs.
The butterfly came on the 340 TK.
The slide on the 440 tk and the Sting
The floater on the Whip.
Scorpion sleds
Pokin around some more I find one listing for 6 HP more and one for 8 more.
Compression listed is 12.5:1. (thats is gettin up there for stock engines)
Also noted a claim of 4hp more for the slider.
Scorpion sleds
The 77 spec sheet says 40 HP for a whirlwind.
S_Kyle
Scorpion sleds
Post by S_Kyle »
40 is not to bad for the age, the sled doesn't weigh that much so it should be peppy. There is a 3 cylinder cyclone sitting back in a shed a few miles from my hunting cabin, I know the original owner. He said it was the most ignorant sled he has ever worked on, but one of the best he ever owned. Wished he never sold it back when. Might have to go take a look one day.
