What engine is this?? & whats it from??
I have another 440 that I'm tearing down that didn't have a fan housing, so I don't know what it is, other than it's a CCW or Kioritz it has a 68mm bore & I'm pretty sure has a 60mm stroke..
Casting numbers are as follows
Head
Mag side 55000211
PTO side 55000201
Cyl.
Mag 45040000
PTO 45030000
Upper case half 49020000 & GLO-64
Lower case half 49010000 & GLO-65
This was a points engine
Also the heads are for 1/2" reach plugs
Is this a reed motor?
Sorry I ment to put that in, It is a piston ported motor. with only one port on each side of the cyl.
Maybe a 71 Stinger??
speedy295
Post by speedy295 »
should be just a plain jane Kec440 maybe a 440/1 or 2
Todd, It had a green motor mount on it?? LOL.. Seriously, You don't thinks it's a Deere motor??
speedy295
Post by speedy295 »
Nope its an arctic cat motor...they used it in a one year only model, the DeereCat..Kinda looked like a 500, but it had a leaping kitty on the snowflap with antlers.
Kenny and I have been talking about this, I have a motor with the same numbers, but the fan tower says 340/5, which it obviously isn't.
It's my understanding that the engine came out of a 600, so my guess is a '73 440/4
speedy295
Post by speedy295 »
I thought 440/4 have 4 transferports??
This is what I figured out. I think it has to be a 73 model as the 72 models had a 25 mm crank, so it should be from a 1973, 500 with a serial number range of 11,001- 20,000 or 600 below serial number -20,000
Which should make it a 440/4 engine??
speedy295
Post by speedy295 »
I believe late 72s have a 30mm crank too.
My parts book has the CCW part numbers BUT they don't match the casting numbers on the Heads, cyl.s, or cases,
I think I have 440/4 Cylinders here some where, if I can find them we'll compare.
I have seen Deere motors put in Scorps and the plates interchange also.
Was tehre a clucth on it? If so what kind?
Rodimus Prime
Post by Rodimus Prime »
72 500 jd engine from the sounds of it kec 440/2. the 75 kec 440/5 would have four intake ports in cylinders.
72 because of the long reach plug heads.
Just checked the numbers since i have one in house from 72 500 numbers match to what you listed.
Last edited by Rodimus Prime on Sun Jan 11, 2009 12:16 pm, edited 1 time in total.
