sportfire
Rodimus Prime
sportfire
Post by Rodimus Prime »
fuel in the carb stays in the carb unless your vent lines are not crossed in which case it just evaporates. Some non pj carbs have a single vent hole at top these were notorious for being dry all the time.
when working properly and with correct vent lines fuel will stay in carb for about 3 months ( this causes tarnished fuel buildup in bowl )
the float bowl contains enough fuel to start engine and run long enough for fuel to be pumped from tank to carb under normal conditions.
A good ball check is more important on the 72-75 jds because the 10 feet of fuel line is a real pain to prime each and every time you start the sled. ( the bendix carb equipped sleds only used 5 feet still a pain to pump fuel )
the sportfire fuel system is really short completely dry 3 good pulls will have fuel in carb ready to start on a good working system (2 pulls normally but i go extra pull anyways) If it takes more pulls than that to put fuel to carb rebuild fuel pump and change impulse line.
smitfire
Real Name: Dustin Smit
sportfire
Post by smitfire »
What I'm explaining to you sounds like it's starving fuel and not flooding?
wycrumb
sportfire
Post by wycrumb »
I have had good luck with my ball checks, I do have a plunger style prime on my '73 400 and it works great, two shots with that and it starts right up, no choke needed which is esp. good since i changed it over to a tilly and never made a bracket for the choke.
Wycrumb
'82 Kawasaki KZ650 CSR
'74 John Deere 300
'72 John Deere 400
'73 John Deere 400
'73 John Deere 600
'80 John Deere Sportfire 440
smitfire
sportfire
Post by smitfire »
started another post
