Walbro Wdb Vs Wda
DLDeere
Real Name: Howard Olson
Walbro Wdb Vs Wda
Post by DLDeere »
What is the difference between the Walbro WDB-31 that is in the JD 300 Kohler and the Walbro WDA-32 on the JD 400 CCW?
I see a venturi on the WDA-32 but any other difference?
Will one provide better performance than the other?
And finally, any problem using the WDA-32 from the 400 CCW on the Kohler engine?
Howard
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
The Hunter
Walbro Wdb Vs Wda
Post by The Hunter »
I have the exact same 2 carbs, I'm going to try and get the wdb-31 carb going with parts from the wda-32.
I imagine there would jetting differences between the 2 since they are different motors. I think your 300 would run stupid rich with the WDA-32 carb
DLDeere
Walbro Wdb Vs Wda
Post by DLDeere »
Hunter,
I've had the 300 running with the wda-32. Seems to be fine. I haven't had it on snow yet (we don't have any yet!) so it hasn't been on load, but I think it will be OK. I found out that the number is the size of the carb throat in millimeters. So the only difference in size is 1 mm. It fit fine on the 300 intake manifold.
I think the parts would be interchangeable, except the throttle and choke butterflies from the 32 may not fit into the 31.
Howard
DL Deere
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
ejazz
Walbro Wdb Vs Wda
Post by ejazz »
Howard-
Wondering if you have any more info on using the WDA-32 on your 300?
Rodimus Prime
Walbro Wdb Vs Wda
Post by Rodimus Prime »
venturi size is the biggest difference smaller engines 340 295 not a big performance gain. 400 - 440 go with the bigger opening to prevent starving. The walbro carb when working is actually a really good carb for trail running. wf carbs are a real pain but kinda neat in thier own way i have one somewhere.
The Hunter
Walbro Wdb Vs Wda
How well would a WDA-6 work on a 1977 Kolher 300?
