I need some help with the following serial numbers. I'd like to know what year these machines are & if any of the following would interchange with a 295s? I have a bare 295s tunnel I'd like to make a rideable machine.
1) 011625m
2) 017396m
3) 022219m
4) 022224m
Thanks in advance,Dave
BOTTOMS UP!!
Help with serial #'s
- Real Name: Dave
- JDXspec
- Real Name: Dustin
http://www.jdsleds.com/models/models.html
click on your model series and it'll give the serial range for each yr. Most parts interchange except the engin parts.
- Real Name: Dave
If I read it correctly #1 & #2(which are 400's) are 1972, #3 & #4 (which are 300's) are 1974. Of the four I had listed, would anyone be better than another as far as putting the 295 together?
The 295/S had CDI ign. Twin carbs, Piston Ported & Comet clutch, so if any of the above has CDI & a Comet clutch then that would probably be the way to go. I guess it depends on how accurate you want to try to be??
Also the 295/S had like mentioned above a engine all it's own, also the exhaust was 295/S specific. There was one other Deere that used a similar exhaust, I can't tell you which?? Someone more familiar with the 100 series sleds will be able to tell you which, if your making it a bogie or slide suspension sled then the 100 series will work, BUT if your looking at a bogie/slider that was again 295/S specific & very rare & hard to find..
Ken
Ken
- Real Name: Dave
I'd just like to put it together as corretly as possible. I have purchased two of the above mentioned sleds, yet to be determined which two. Also included in the sale was a truck load of parts & a brand new, just out of the box seat.
Almost, the 400s are 73 since the numbers are over 11,000. The 300s are probably closer for misc. parts.bottomsupduckclub wrote:If I read it correctly #1 & #2(which are 400's) are 1972, #3 & #4 (which are 300's) are 1974. Of the four I had listed, would anyone be better than another as far as putting the 295 together?
An X8 set up, particularly a '75, would be the closest.
The serial numbers started over for the X line, so I don't really know what you are looking at.
- Real Name: Dave
I guess my goal would be to try to re-assembly this tunnel back into it's former glory, or as close as I can come.
Dave,
If the purchase was for the specific purpose of putting together a 295/S, I'd have to go with #3 and #4 as they are the correct model year. This way more parts may work out for you, but condition would have to be evaluated to decide for sure.
-John
-John
