The JDX8 Runs!
- GreenFever
The JDX8 Runs!
Finally got the '75 X8 running today. Thanks to Rich and the local salvage yard. Idles and starts great but it will not accelerate. It will only move about 5mph. Doesn't sound like it is missing so I am guessing I screwed up the carb rebuild. Any body have an ideas what to look for?
The electrical issues are the ignition switch doesn't work but the kill switch does. No dash lights or tail light but the brake light works. The tack is also not functioning. I swapped the wiring harness off a '76 400 because the original one was a little tore up so I may not have got everything plugged in and grounded correctly under the dash. Some ideas would be helpful here also.
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 600 missing engine parts
'75 800 not running
'73 JDX4 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The JDX8 Runs!
It isn't as obvious as you would think to tell if it is running on both cyls.
That said, I have found that my '74 X8 will run about 30 mph on one cyl.
If you have black goo dripping out the exhaust, it's not running on both cyls.
Check the metering lever in the carb for proper adjustment .
Fuel pick up in the tank plugged? clamps on lines? is gas going through the lines when it is running ( bubbles )?
Get the electrical issues fixed. You need to eliminate all the potential issues you can.
- GreenFever
The JDX8 Runs!
I got all the electical issues sorted out but the ignition switch. I think it might just need a new one. Now that the tack is working I can see that it will only rev to 5000 with the track off the ground. No black goo out the exhaust and lots of fuel running through the lines. Plugs are a bit wet. Could it be the CDI box causing this also?
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The JDX8 Runs!
There is a FAQ for trouble shooting the CDI system. Sounds like a good posibility that the problem lies in the stator or CDI box.
- GreenFever
The JDX8 Runs!
Well it is not the CDI swapped a few different ones on there no difference. I know it is a no no but I also took the belt off just to see if the secondary or something was the problem and still only 5000rpms.
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The JDX8 Runs!
Go back into the FAQ section that Brian mentioned and check the stator ohms. The high speed windings may be at fault.
- GreenFever
The JDX8 Runs!
The high speed coil is 55 ohms. Does that mean it is junk?
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The JDX8 Runs!
The target ohm reading for the high-speed coil is around 76 ohms. given a 10-15% difference either way is acceptable. Your reading of 55 is below the acceptable range. I would say it could be bad. Are you sure that you have both plugs firing. The best methos of checking is to use an in-line spark tester. This connects between the spark plug and the plug wire and flashes when it has spark when running.
- GreenFever
The JDX8 Runs!
I don't have a in-line spark tester but when I pull it over with the spark plugs out but still hook to the wires it has spark and it will idle fine. I have also swapped one of the coils with no difference. Is it possible to have spark on both cylinders at idle but not and higher rpms?
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
- GreenFever
The JDX8 Runs!
Got a different stator from the salvage yard today. Now the X8 runs great. Just need to fine tune the carb. What should the rpms be at wot?
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The JDX8 Runs!
Yes, it is possible for a no spark condition at high speed.
I don't know the governed rpm's but set the starting point of the high speed needle at 1-1/8 turns from lightly closed. Take the sled for a ride and turn the high speed needle 1/8 turn or less at a time either way to obtain optimum performance, then turn needle 1/8 turn counterclockwise for final adjustment
Last edited by harleysportster on Wed Jan 21, 2009 10:26 pm, edited 1 time in total.
The JDX8 Runs!
Glad to hear you have it running.
Last edited by harleysportster on Wed Jan 21, 2009 10:27 pm, edited 1 time in total.
- Real Name: Kevin Campbell
The JDX8 Runs!
Keep that 440/22 close to 7000 rpm on the top end.
We need to see some pics of your sled!
Kevin Campbell
Vicksburg, Michigan
Vicksburg, Michigan
- GreenFever
The JDX8 Runs!
Here is a pic from before I started. It looks a better now after I cleaned it up and got a better hood. Still needs a seat and eventually a full restoration.
'72 500 x2
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
'72 400 not running
'73 400 parts sled
'74 300 not running
'75 800 not running
'74 JDX6
'75 JDX8
The JDX8 Runs!
:suprised: Holy Lichens Batman, that sled has been sitting out for a spell!
