Ok have to ask which spark system you have points or cdi? So far it sounds like bad connection around voltage regulator either bad ground(black) or not hooked in to voltage circuit (yellow).
Which type of voltage regulator do you have the little black box with single yellow wire or the aluminum box with a yellow and black wire? aluminum box btw that black wire should be grounded to frame.
75' JDX8
75' JDX8
We went though the fuel pump on the carb and its good. But the pulse line dose act a little weak to me. How hard should it pulse ? I'll clean the tank pickup, check compression, and put in new crank seals. I'm leaving on a U.P. trip on Sunday and I'll be back here on Thursday. So I'll work on it when I get back.
nick
nick
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
75' JDX8
How do you tell if it has points or CDI ? The regulater is the little black box with one yellow wire.Rodimus Prime wrote:Ok have to ask which spark system you have points or cdi? So far it sounds like bad connection around voltage regulator either bad ground(black) or not hooked in to voltage circuit (yellow).
nick
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
75' JDX8
cdi would have a ugly looking box near carb with wires going to the engine and coils. points is just nice wires to connecter and coils.
75' JDX8
I have a box on the firewall that says Presto-lite. It must be the CDI type.Rodimus Prime wrote:cdi would have a ugly looking box near carb with wires going to the engine and coils. points is just nice wires to connecter and coils.
nick
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
