1980 trailfires
JD82KID
1980 trailfires
Post by JD82KID »
I picked up the 2 TF 340 on Friday. One starts up on first pull, the other needs starter fluid sprayed in, then it fires up. What causes this problem? Does it need adjusting or cleaning?
They came with manuals and a tech manaul all for $600.00, and they look pretty good!!
JD82KID
1980 trailfires
Post by JD82KID »
JD82KID
1980 trailfires
Post by JD82KID »
S_Kyle
Real Name: Scott Kyle
1980 trailfires
Post by S_Kyle »
The carb probably needs cleaned. Having the manuals will help a lot, it will very clearly explain the proper cleaning procedure. Those power jet carbs can be a pain to get clean.
Check the fuel pump and fuel lines wile your at it.
smitfire
Real Name: Dustin Smit
1980 trailfires
Post by smitfire »
choke may need an adjusting, clean carb
Rodimus Prime
1980 trailfires
Post by Rodimus Prime »
trailfire 340s came with non pj carbs just regular 34 miks.
JD82KID
1980 trailfires
Post by JD82KID »
what is the best carb cleaner to use? Will I have to take the float bowl apart to clean?
Has anyone used a product called seafoam? I heard this works pretty good?
S_Kyle
1980 trailfires
Post by S_Kyle »
I have never used sea foam cleaners, but have use some of there other products. They work great but are pricey.
Normally I use kleen flo carb cleaner and dunk, but have used all kinds of different types and they all work. To properly clean the carb it will have to be taken completely apart. I mentioned it before read the section in your tech manual about cleaning the carb if you are unsure of the proper procedure. The carb may have to be dunked and soaked to get all the crud out of the carb.
JD82KID
1980 trailfires
Post by JD82KID »
Will I be able to use the same gasket, or put on a new one, if so, where can I get one?
S_Kyle
1980 trailfires
Post by S_Kyle »
You shouldn't need anything to clean the carb. Unless the jets are so bad they need replaced.
1980 trailfires
Those appear to be very nice. $600 was a deal to be sure.
big danno 1970
1980 trailfires
Post by big danno 1970 »
Nice!!! Now pull those engines and replace the crank seals before you have to change pistons.
