Pre mix gasoline
tmartin
Pre mix gasoline
Post by tmartin »
I was wondering what some of you use as far as premix gas ratios and what oils you use. I have 73 john deere 400 and a 73 arctic cat panther 340. They both say 20:1 for the mix ratio. Does this hold true to today or was this for the old oils out there? Thanks for the input. I just don't want to wreck anything.
1988 & 1991 Polaris Indy 650s
S_Kyle
Real Name: Scott Kyle
Pre mix gasoline
Post by S_Kyle »
I have found that 20:1 in a few places but, very few sleds will run well on that heavy of a mix. I would say 40:1 for the 400 as that is what my friends and I use for the early Deere's.
Rodimus Prime
Pre mix gasoline
Post by Rodimus Prime »
Todays 2cycle oil is different running 50:1 is the norm for sleds. An exception to be made is when your doing an engine breakin ( new rings or pistons) Do Not Use sythetic oils during this time. Running more oil than that at anytime is not only a waste, harmful to enviroment, it stinks and hurts eyes.
Truthfully with many of todays premium oils you can run these sleds with a leaner oil mix but i dont like the risk myself.
Mr. Deere
Pre mix gasoline
Post by Mr. Deere »
Nice work. So that means 87 really ain't 87 at that Point.
Pre mix gasoline
I use Klotz pre-mix in everything, then I don't worry if I mixed it for the sleds or not, JD 4 stroke push mower, JD 317, & sleds... Hey I just love the smell of Klotz
:sled: :sled: :sled: :sled:
thearcticfisherman
Pre mix gasoline
Post by thearcticfisherman »
50:1 is just fine,thats what i run in my 72 400, RUNS LIKE A DEERE
