How much oil goes into the chain case on an 80's Fire series? Is it like an auto and fill until it comes out the fill hole? Also what weight is used?
Thanks, Dennie
Oil in Chain Case
Oil in Chain Case
The answer is in the FAQ section
Oil in Chain Case
Iv always used 80/90 wieght gear lube
put oil in the top hole until it comes out the bottom hole.
Oil in Chain Case
I use ATF in all chaincases. 80/90 does not flow in colder temps. It all depends on what your general temps are. I live in Manitoba and the winters can get a bit cold ( especially this year or so it seems ) Maybe I'm getting older. Anyway, ATF still flows in colder temps and works fine when it warms up.
Jeff
Jeff
Lockport, MB.
Gotta love a 2 stroke !
