Liquifire Carbs
Liquifire Carbs
I have a 440 CCW and i need carbs any idea best carb for best performance. I might be boring out the cylinders for larger pistons. Any ideas where i can find a new carb that will still work for the engine. or an engine that will be an easy swap to the JD liquifire 77
Liquifire Carbs
Whats wrong with the original carbs? The orignal carbs work just fine and can be rejetted accordingly. Boring out the cylinders to the next size will not increase the engine very much at all, it is done to correct the clearance of the cylinder to piston.
You can swap in a fan cooled 440/22 series engine directly, you will have to reuse the liquifire intake and exhaust.
Liquifire Carbs
I am looking for carbs but i cannot find any online that are not for 100 buck. I am looking for same size and not for a ton of cash.
