I NEED HELP WITH A JD300, PLEASE!!!!!
You could use a match book but I think a screwdriver would be easier.
Thanks guys, I got my Johndeere started yesterday, It was a pain in my A*% getting the points set just
right. Now i have a carb problem, She is getting way to much gas, But this is a simple problem.
Now i'm at this problem. Now the motor floods out, with what smells like water... It does want to start,
and the water in the recoil side cylinder is rust colored. Now what is wrong with this thing?????
- Real Name: Howard Olson
Check out the link "Technical Information" at the home page of this website, then click on "Troubleshooting for beginners". You may get many of the answers you need.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Detroit Lakes, MN
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
Why is it whenever someone drags home a sled that has not been run in years the first thing that want to do is get the engine started?
You have water in either your gas tank or your crankcase or both. Probably also dirt.
With water in the crank there is a good chance you have rusted springs on your center seals and it is not going to ever run right.
Sorry to sound so grim but .... been there, seen that.
Order a full gasket set with seals and fully take apart the motor, clean it check for ware and damage to cylinders, pistons, crank case, and clean the carb. you put back together and with the timing set right it run good for a long time. and make sure there is no water in the tank, and new fuel lines are cheap so it good to change out the 35 year old ones just to be reliable.
nick
nick
72 500
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
77 440 cyclone spitfire
78 spitfire x2
79 spitfire
80 spitfire x3, liquifire x2, sportfire
81 spitfire
82 sprintfire, spitfire, 340 trailfire x2
83 snowfire
84 sprintfire, snowfire, trailfire lx
73 600
74 295/s, JDX6
75 340/s, 400, JDX8
76 440 liquifire
78 spitfire x2
79 spitfire
81 spitfire
83 snowfire
