Question
Question
79 trailfire 440 model runs good for 20 - 30 min then "lays down". Will set and idel for 3-4 min. Then it is ready to go again. Basically the more you run it the slower it get overall. Have been told it is a stator problem but need to know what the readings should be. Have also been told is the secondary clutch but that has been cleaned and checked out and seems to be OK. Any advice appreciated. Thanks
