87 ski-doo formula plus
elkhunter970
Hey all I have a 87 plus that has got me puzzled it starts fine and idles great but when you hit the throttle it bogs and wont pull itself. I have cleaned the carbs checked crank seals it has good spark. It also is blowing gas out of both carbs when you rapp it up. My buddy seems to think its the rotary valve does anyone have any ideas??? any help will be appreciated
Or the valves as you mentioned. Sounds like an exhaust restriction.
elkhunter970
Thanks for the heads up on the mouse nest
Pulled the pipe off and sure enough the little fellers had been working over time so after some choice words and a little digging the plus is ready for some fun in the snow.thanks again
Wow...you guy are good!
