1976 Sno Jet Astro
jasoniowa
1976 Sno Jet Astro
Post by jasoniowa »
I picked up a 1976 Sno Jet Astro, it has a kawasaki 440 engine. I am having trouble finding out what the points should be gapped at. I am getting no spark right now. Any info on the Sno Jet would be great. There are a few websites out there but not much for info.
My sleds, 1982 Liqufire, 1980 Trailfire, 1977 Sno*jet SST.
Rodimus Prime
1976 Sno Jet Astro
Post by Rodimus Prime »
0.014-0.016 point gap.
1976 Sno Jet Astro
A 76 should have a Yamaha engine. A 77 would be Kawwy powered.
jasoniowa
1976 Sno Jet Astro
Post by jasoniowa »
Yep it is a 77 read it wrong.
jasoniowa
1976 Sno Jet Astro
Post by jasoniowa »
I set the points gap but still no spark. Does anyone have a service manual?
1976 Sno Jet Astro
Jason did you unplug the engine electrical connector and see if you get spark then?
If you have an ohm meter you can test the internal and external coils, plug wires, grounds ect.
If you don't have a meter buy one. I bought one at Sears on Black Friday for $10.
jasoniowa
1976 Sno Jet Astro
Post by jasoniowa »
O.k. my son was messing around with the points and set one at like .020 and the sled had spark on both sides but it was stronger on one side then the other and also the spark was orange not blue. So I tried to set the other point at the same and now no spark again. Now no matter what you set them at I still have not spark just like i origanally had. Any thoughts??
JDFanPa
1976 Sno Jet Astro
Post by JDFanPa »
If these are used points are you sure they have been cleaned throughly.
RAT540
Real Name: DAVE
1976 Sno Jet Astro
Post by RAT540 »
IF THEY ARE NEW POINTS THEY ARE SHIPPED WITH A THIN PROTECTIVE COATING ON THEM,COUPLE SWIPS WITH EMERY PAPER SHOULD CLEAN THEM UP.
75 800 440
79 TRAILFIRE 440
79 KAWI INVADER 440
06 SKI-DOO MACH Z 1000CC
jasoniowa
1976 Sno Jet Astro
Post by jasoniowa »
Well we got the sno jet running, had to set the points correctly and clean them. Now I just need some snow.
